Question / Help I need help for arma 3 recording settings. (dummy needs bit help)
mx0mania
Hi. And sorry for advance. I know that there might be tips on previous guides but im not sure wich use cos there is so many.
Im recording Arma 3 and it does not seem to be so smooth at my new pc as it was before with my old amd rig. It looks like its missing frames or something. And when I turn its bit blurry. I have tried differend settings but I turn to you experts. I know shadowplay might be more easy for dummies but its not option now. I had so many broblems with gforce experience that I deleted it. I list my specs below so you can make your suggestions more effectively.
Monitor. Asus ROG PG348Q 3440x1440 at 100Hz.
CPU: I9 9900k
GPU: rtx2080
RAM: 16gt DDR4 3200MHz
Game is on SSD and record folder is on same SSD.
My OBS studio settings ATM
Output --> recording
Type: Standard
Format: mp4
Encoder: NVIDIA NVENC H.264 (new)
Rate control: CQP
QG level:15
Keyframe interval: =
Preset: Quality
Profile: High
Look ahead: On
Psycho visual tuning: on
Gpu: 0
Max b-frames: 2
Video
Base canvas resolution 3440x1440
Output 2580x1080
Downscale filter Bilinear
Common fps values.
At the end for more info: Arma does not runt at 100fps at multiplayer because i run antistasi with same pc. But same broblems are at singleplayer even with stable 90fps.
