Question / Help I need a bit of help with my Stream settings, Stream looks blurry.!!
Lanem
Hello there,
I know from my logs you will see that my PC is not a high end or not even close to that what so ever!.
For the past 2 3 days that i'm trying to start streaming mostly for my own plesure i see that my Stream is blurry and becomes even worse if there is a lot of action on my screen. I can say that my bitrate is low really low. I think i can get it up by 100-300 kbps more but that will be that! ( number are on the log )
Is there any way for me to make my stream quality more crisp like?
If my english are bad forgive me. It's not my native language.!!
(will update the post with a short twitch clip..)
edit: https://clips.twitch.tv/ObliviousCaringPoxOSsloth
LOG: https://gist.github.com/8729000eddbee032fe7c9bb26a882c25
Harold
Start by switching to 30fps, it requires between 50% and 100% more bitrate and a flat 100% more cpu time to maintain quality.
Or better yet, run the autoconfiguration wizard in the tools menu.
Lanem
The Wizard produce even worse quality than i had.
Just to make a quick note. I'm not dropping frames, out of 4 hours o stream yday i had 0.01% lose.
I went back to 30fps, gave a bit of more bitrate to 1800 or so. still not smooth stream.
With my hardware would i be able to achieve a clear 720p 30/60 fps stream, or on my case is purely a bitrate issue? I'm just asking because that so i don't consume your time more than i already have!
