Question / Help i have a problem with obs not recording my games audio.
P1ayer76
i have a problem with obs not recording my games audio. when i use obs it picks up the game audio but does not record it.
my log-
15:01:39.092: CPU Name: AMD Ryzen 5 1600 Six-Core Processor
15:01:39.092: CPU Speed: 3200MHz
15:01:39.092: Physical Cores: 6, Logical Cores: 12
15:01:39.092: Physical Memory: 8144MB Total, 5903MB Free
15:01:39.092: Windows Version: 10.0 Build 16299 (revision: 15; 64-bit)
15:01:39.092: Running as administrator: false
15:01:39.092: Aero is Enabled (Aero is always on for windows 8 and above)
15:01:39.092: Windows 10 Gaming Features:
15:01:39.092: Game DVR: On
15:01:39.093: Sec. Software Status:
15:01:39.094: Windows Defender Antivirus: enabled (AV)
15:01:39.094: Windows Firewall: enabled (FW)
15:01:39.095: Windows Defender Antivirus: enabled (ASW)
15:01:39.102: Portable mode: false
15:01:39.183: OBS 21.0.1 (64bit, windows)
15:01:39.183: ---------------------------------
15:01:39.184: ---------------------------------
15:01:39.184: audio settings reset:
15:01:39.184: samples per sec: 44100
15:01:39.184: speakers: 2
15:01:39.206: ---------------------------------
15:01:39.206: Initializing D3D11...
15:01:39.206: Available Video Adapters:
15:01:39.207: Adapter 1: Radeon RX 580 Series
15:01:39.207: Dedicated VRAM: 4237844480
15:01:39.207: Shared VRAM: 4270213120
15:01:39.207: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:01:39.216: Loading up D3D11 on adapter Radeon RX 580 Series (0)
15:01:39.302: D3D11 loaded successfully, feature level used: 45056
15:01:40.051: ---------------------------------
15:01:40.051: video settings reset:
15:01:40.051: base resolution: 1920x1080
15:01:40.051: output resolution: 1280x720
15:01:40.051: downscale filter: Bicubic
15:01:40.051: fps: 60/1
15:01:40.051: format: NV12
15:01:40.052: Audio monitoring device:
15:01:40.052: name: Default
15:01:40.052: id: default
15:01:40.052: ---------------------------------
15:01:40.085: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
15:01:40.102: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
15:01:40.561: [AMF] Version 2.3.1 loaded (Compiled: 1.4.4.0, Runtime: 1.4.6.0, Library: 1;4;6;0;17.50.33.05;201803221826;CL#1530970).
15:01:41.205: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:01:41.231: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:01:41.254: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:01:41.266: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:01:41.266: [browser_source: 'Version: 1.29.0']
15:01:41.302: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
15:01:41.302: (126)
15:01:41.771: Couldn't find VLC installation, VLC video source disabled
15:01:41.930: No blackmagic support
15:01:42.749: ---------------------------------
15:01:42.749: Loaded Modules:
15:01:42.749: win-wasapi.dll
15:01:42.749: win-mf.dll
15:01:42.749: win-dshow.dll
15:01:42.749: win-decklink.dll
15:01:42.749: win-capture.dll
15:01:42.749: vlc-video.dll
15:01:42.749: text-freetype2.dll
15:01:42.749: rtmp-services.dll
15:01:42.749: obs-x264.dll
15:01:42.749: obs-vst.dll
15:01:42.749: obs-transitions.dll
15:01:42.749: obs-text.dll
15:01:42.749: obs-qsv11.dll
15:01:42.749: obs-outputs.dll
15:01:42.749: obs-filters.dll
15:01:42.749: obs-ffmpeg.dll
15:01:42.749: obs-browser.dll
15:01:42.749: image-source.dll
15:01:42.749: frontend-tools.dll
15:01:42.749: enc-amf.dll
15:01:42.749: coreaudio-encoder.dll
15:01:42.782: ==== Startup complete ===============================================
15:01:42.798: Service '' not found
15:01:42.871: All scene data cleared
15:01:42.871: ------------------------------------------------
15:01:42.925: WASAPI: Device '4 - VG245 (AMD High Definition Audio Device)' initialized
15:01:42.991: WASAPI: Device 'Headphones (2- Turtle Beach Recon 60P)' initialized
15:01:43.006: WASAPI: Device 'Microphone (2- Turtle Beach Recon 60P)' initialized
15:01:43.064: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
15:01:45.457: Switched to scene 'Scene'
15:01:45.469: ------------------------------------------------
15:01:45.469: Loaded scenes:
15:01:45.469: - scene 'Scene':
15:01:45.469: - source: 'Game Capture' (game_capture)
15:01:45.469: - source: 'Game Capture 2' (game_capture)
15:01:45.469: - source: 'BrowserSource' (browser_source)
15:02:00.440: User Removed source 'BrowserSource' (browser_source) from scene 'Scene'
15:02:03.079: ==== Shutting down ==================================================
15:02:03.087: Switched to scene '(null)'
15:02:03.099: WASAPI: Device '4 - VG245 (AMD High Definition Audio Device)' Terminated
15:02:03.102: WASAPI: Device 'Headphones (2- Turtle Beach Recon 60P)' Terminated
15:02:03.104: WASAPI: Device 'Microphone (2- Turtle Beach Recon 60P)' Terminated
15:02:03.109: All scene data cleared
15:02:03.109: ------------------------------------------------
15:02:03.153: Freeing OBS context data
15:02:03.567: [Scripting] Total detached callbacks: 0
15:02:03.631: == Profiler Results =============================
15:02:03.631: run_program_init: 6857.65 ms
15:02:03.631: ┣OBSApp::AppInit: 23.923 ms
15:02:03.631: ┃ ┗OBSApp::InitLocale: 8.826 ms
15:02:03.631: ┗OBSApp::OBSInit: 6707.51 ms
15:02:03.631: ┣obs_startup: 11.706 ms
15:02:03.631: ┗OBSBasic::OBSInit: 6509.91 ms
15:02:03.631: ┣OBSBasic::InitBasicConfig: 0.335 ms
15:02:03.631: ┣OBSBasic::ResetAudio: 0.15 ms
15:02:03.631: ┣OBSBasic::ResetVideo: 867.511 ms
15:02:03.631: ┣OBSBasic::InitOBSCallbacks: 0.005 ms
15:02:03.631: ┣OBSBasic::InitHotkeys: 0.044 ms
15:02:03.631: ┣obs_load_all_modules: 2698.22 ms
15:02:03.631: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.418 ms
15:02:03.631: ┃ ┣obs_init_module(enc-amf.dll): 633.348 ms
15:02:03.631: ┃ ┣obs_init_module(frontend-tools.dll): 17.394 ms
15:02:03.631: ┃ ┣obs_init_module(image-source.dll): 0.004 ms
15:02:03.631: ┃ ┣obs_init_module(obs-browser.dll): 2.597 ms
15:02:03.631: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.48 ms
15:02:03.631: ┃ ┃ ┗nvenc_check: 0.451 ms
15:02:03.631: ┃ ┣obs_init_module(obs-filters.dll): 0.015 ms
15:02:03.631: ┃ ┣obs_init_module(obs-outputs.dll): 0.006 ms
15:02:03.631: ┃ ┣obs_init_module(obs-qsv11.dll): 87.012 ms
15:02:03.631: ┃ ┣obs_init_module(obs-text.dll): 8.052 ms
15:02:03.631: ┃ ┣obs_init_module(obs-transitions.dll): 0.007 ms
15:02:03.631: ┃ ┣obs_init_module(obs-vst.dll): 0.002 ms
15:02:03.631: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
15:02:03.631: ┃ ┣obs_init_module(rtmp-services.dll): 46.524 ms
15:02:03.631: ┃ ┣obs_init_module(text-freetype2.dll): 0.08 ms
15:02:03.631: ┃ ┣obs_init_module(vlc-video.dll): 0.039 ms
15:02:03.631: ┃ ┣obs_init_module(win-capture.dll): 0.086 ms
15:02:03.631: ┃ ┣obs_init_module(win-decklink.dll): 2.357 ms
15:02:03.631: ┃ ┣obs_init_module(win-dshow.dll): 3.642 ms
15:02:03.631: ┃ ┣obs_init_module(win-mf.dll): 524.988 ms
15:02:03.631: ┃ ┣obs_init_module(win-wasapi.dll): 0.007 ms
15:02:03.631: ┃ ┗reset_win32_symbol_paths: 0.114 ms
15:02:03.631: ┣OBSBasic::ResetOutputs: 15.804 ms
15:02:03.631: ┣OBSBasic::CreateHotkeys: 0.042 ms
15:02:03.631: ┣OBSBasic::InitService: 20.889 ms
15:02:03.631: ┣OBSBasic::InitPrimitives: 11.889 ms
15:02:03.631: ┗OBSBasic::Load: 2644.69 ms
15:02:03.631: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.004 ms, max=0.305 ms, 99th percentile=0.036 ms, 100% below 25 ms
15:02:03.631: audio_thread(Audio): min=0 ms, median=0.042 ms, max=7.649 ms, 99th percentile=0.113 ms
15:02:03.631: obs_graphics_thread(16.6667 ms): min=0.164 ms, median=0.648 ms, max=2402.33 ms, 99th percentile=2.244 ms, 99.7586% below 16.667 ms
15:02:03.631: ┣tick_sources: min=0.001 ms, median=0.007 ms, max=2401.88 ms, 99th percentile=0.041 ms
15:02:03.631: ┣output_frame: min=0.162 ms, median=0.398 ms, max=2.557 ms, 99th percentile=0.959 ms
15:02:03.631: ┃ ┣gs_context(video->graphics): min=0.093 ms, median=0.17 ms, max=2.556 ms, 99th percentile=0.677 ms
15:02:03.631: ┃ ┃ ┣render_video: min=0.025 ms, median=0.054 ms, max=0.984 ms, 99th percentile=0.121 ms
15:02:03.632: ┃ ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.022 ms, max=0.152 ms, 99th percentile=0.058 ms
15:02:03.632: ┃ ┃ ┃ ┣render_output_texture: min=0.003 ms, median=0.009 ms, max=0.858 ms, 99th percentile=0.032 ms
15:02:03.632: ┃ ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.011 ms, max=0.409 ms, 99th percentile=0.018 ms
15:02:03.632: ┃ ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.006 ms, max=0.929 ms, 99th percentile=0.016 ms
15:02:03.632: ┃ ┃ ┣download_frame: min=0 ms, median=0.005 ms, max=1.022 ms, 99th percentile=0.01 ms
15:02:03.632: ┃ ┃ ┗gs_flush: min=0.032 ms, median=0.106 ms, max=1.686 ms, 99th percentile=0.214 ms
15:02:03.632: ┃ ┗output_video_data: min=0.154 ms, median=0.231 ms, max=0.828 ms, 99th percentile=0.443 ms
15:02:03.632: ┗render_displays: min=0 ms, median=0.238 ms, max=18.866 ms, 99th percentile=1.436 ms
15:02:03.632: video_thread(video): min=0.001 ms, median=0.001 ms, max=0.023 ms, 99th percentile=0.003 ms
15:02:03.632: =================================================
15:02:03.632: == Profiler Time Between Calls ==================
15:02:03.632: obs_hotkey_thread(25 ms): min=24.798 ms, median=25.085 ms, max=25.589 ms, 99.8954% within ±2% of 25 ms (0% lower, 0.104603% higher)
15:02:03.632: obs_graphics_thread(16.6667 ms): min=13.867 ms, median=16.667 ms, max=2402.34 ms, 99.5169% within ±2% of 16.667 ms (0.241546% lower, 0.241546% higher)
15:02:03.667: Number of memory leaks: 9
