Question / Help I can't set both desktop audio and my microphone to track 1 without running into bugs.
Riot.Goliath
So I can record multiple audio tracks by setting my desktop audio to track 1, my mic to track 2, and both of them to track 3. That works perfectly.
What I can't do is set both of them to track 1, my mic to track 2, and desktop audio to track 3. When I do that, I should get the same outcome (in a different order) but instead, I get three tracks. Two of them record both my mic and desktop, and the third is silence. What's up with that?
The reason I would prefer to do it this way instead of the first way that works is because when I'm using VLC to play my videos to check the quality, it defaults to track 1 so I have to manually set it to track 3 every single time or my mic is muted. So I was hoping to be able to record both on track 1, so VLC would play track 1 and I'd be able to hear everything while still having the ability to separate track 2 and 3 for editing.
Thanks.
You intend to do the right thing, but you seem to made a mistake in the advanced audio properties that creates the mapping which source should go into which track. Please post a screenshot of this (Menu Edit->Advanced Audio Properties). In the first column (track 1), you should check both mic and desktop audio, in the second column(track 2) your mic source only, and the third column (track 3) desktop audio only.
