I am trying use create a scene in OBS to use in Zoom. (windows 10 64)
I cant find a way in Zoom to select the audio output from OBS (Im using virtual OBS cam and that shows fine in Zoom).
If anybody can help, I would be most grateful.
In zoom in the audio setting the only choice is 'same as system' or the webcam -no OBS choice as source.
In zoom in the share advanced section I can select 'share computer sound only'
but so far I cant find any option that works, neither can I set a virtual audio output for Zoom from within OBS.
Help!!
Help!!
