diabolique6
Hello
So i would like make a movie from Presonus Studio One but haven't sound from my audio sequencer in recordings,when starting OBS before S1.
When open S1 first i have the sound but video file after recording is without sound.
Asioforall driver shows the audio device is used by another program...
When using orginal driver i have the same situation.
I get the sound from mics(camera and headphone mic)
Ive attached an image and log file.
Please tell me how i can get it working or what is the problem.
Thanks in advance
FIXED : i had sticked option in control panel of original driver in DAW called "exclusive mode" which blocked signal.
Signal from ASIO do not work with OBS.
Btw before i found this post. https://obsproject.com/forum/threads/how-to-stream-daw-audio-with-an-audio-interface.14792/
i had to install 32 bit version of sequencer to see plugin and works too but it gives strange delay 1:1 this is not latency problem xD
Now i have problem with low quality audio from OBS. ARGH!
Thanks in advance
