Hi,
We often meet many situation where actual frame rate doesnt match the final output(stream) frame rate, such as the in-game frame rate is higher than output frame rate. So I wonder how will OBS program do to change the frame rate? In other situation like dropping frames(because of encoding lag or other reasons), what will OBS do? If the actual frame rate is lower than output frame rate after dropped(like OBS get 20 frames but need to output 60 frames in one second), what will it do? Will it duplicate some frames to keep the output fps?
Thank you!
Thank you!
