Perraddidle
Hi, I have a dual PC setup. My capture card is an Elgato 4k 60 pro mk2, It's receiving a 1440p 144hz signal from a cloned Samsung g7 set to 240 hz.
The capture/streaming PC has 16 gigs of ddr4, 2933 mhz, an i5 8500 cpu and a Gtx 1660 gpu. SSD hardrive.
If I game without OBS on everything is great. If I open up OBS, I get input lag on the gaming pc, even though it's not running OBS. It;s only connected to the capture PC with 1 HDMI. I'm not doing passthrough, just input to the 4k60.
I get less input lag if I shut off the preview window, even less input lag if I minimize OBS and don't have it open on the screen. But there is still some compared to not having OBS running.
This fries my brain as a dual PC setup should eliminate issues like this. I wonder if it because the CPU is an older i5 8500. It's also the same when I use nvenc on the 1660. In fact I always use the nvenc new.
Does anyone else have this kind of issue?
