How do I monitor audio from Siig Honetech USB VHS Video Grabber capture device through VoiceMeeter Potato while I am recording a video/audio from a VHS deck? Clearly I'm a newbie making this more complicated by using VoiceMeeter - but I was hoping to both live stream the VHS Video tapes with voice over, and additional video content, and record the live stream session. Then at a different time, I intend to simply digitize the VHS tape.
Hardware & Software: A cheap SIIG / Video Grabber USB2.0 Capture hardware using OBS on a Windows 10 desktop, w/ Voicemeeterset as the default, w/ 1 Usb headset + mic in for voice over and headphone monitoring, an another output to the desktop Realtek device driver (WDM) to speakers. In other words, I route all Audio on my computer hardware and virtual input and output sources through VoiceMeeter Potato - then route and mix audio sources to headphones, speakers, OBS (if recording) or live streams as needed.
So, how do I route the USB video Grabber audio that's coming from the capture device and being metered in OBS - and send that audio to VoiceMeeter - either VAIO, AUX or VAIO3 so I can monitor it through headphones or speakers WHILE I record the VHS video and audio in OBS - or live stream it?
Here's how OBS is configured:
In OBS, the video source is set to the VHS deck Video Grabber and displays correctly as expected. (surprisingly well in fact) . The video USB Grabber's audio source is also automatically being routed and metered as expected in the OBS Audio Mixer - so I see there is an active audio signal with the same Source Name.
I didn't have the option to capture the USB Video Capture device's Audio signal by creating a separate audio source in OBS - nor can the audio from the USB video Grabber device be routed to VoiceMeeter. The audio and the video come combined from the USB device into OBS only - which I can't seem to modify.
Under the OBS Audio Mixer, I set the Video Grabber Audio Channel Advanced properties to "Monitor and Output" - and have all Tracks checked.
Under OBS Settings, I tried setting the Advance Audio Monitoring Device to each of the three VoiceMeeter Inputs listed above - one at a time and clicked Apply each time - but never heard (or saw) the USB Video Grabber audio signal through VoiceMeeter - and therefore no audio through speakers or headphones.
Red Herring? However, in OBS, under the Mixer's active audio channel from the video, I clicked the cog wheel and selected "Properties: (which opens that new window to display the video, w/ options to select devices and change formats etc) - then scroll down to the bottom to "Audio Output Mode" - the default setting is Capture Audio Only - BUT if I change that to "Output Desktop Audio (Wave Out)" I can then hear the audio - routed through directly to the external speakers (through the computer's Realtek driver)
