How can I have audio with Default Audio setting? But elgato CAMLINK do not need to be changed?
Fuyuanhsia
I am developing a video capture product. But I found an audio issue. The issue is that I must change audio setting, then I can see audio is on from video capture channel as following image
How can I have audio with Default Audio setting? I found elgato CAMLINK is no need to change default audio setting
My step is "Setup Gaming PC -> HDMI -> Video Capture -> USB ->Streaming PC" as follows
1) Connect HDMI (video+audio) from Gaming PC
2) Playback Local Video file with audio on Gaming PC
3) Install OBS Studio
4) Add "Video Capture Device"
5) Select my video capture under "Video Capture Device" properties and select ok
6) Notice that video from video capture is seen
7) Notice no audio is hear on Local recording or on stream <- Issue
8) Open "Video Capture Device" properties and check "custom audio device"
9) Select the name of my video capture as Audio Device and click ok
10) Notice audio is now heard from local recording and stream
