Hi I need help about obs streaming problem
nhukhoi
This afternoon I was still able to stream on youtube, but just after I stopped the stream and checked for streaming again (because of curiosity), it says starting the output failed, if you're using NVENC or AMD encoders, even though my GT 1030 is not supported to use NVENC and I've been using an x264 encoder the whole time and it still runs good at 60 fps.
Here's my log
WASAPI: Device '{0.0.1.00000000}.{4c8beebc-03f6-4743-bc09-43418f297d7f}' failed to start
That's about the Razer Seiren Mini microphone...
and dont use 75 fps use 60 youtube only suport 60 fps it will drop frames then on 75
18:29:57.163: - source: 'Video Capture Device' (dshow_input)
18:29:57.163: - source: 'Video Capture Device 2' (dshow_input)
2 Viceo capture devices and the usb mic looks like you have an USB bandwitch problem
download this programm and post a screenshot of it !
