Help with Sound into Livestream
timopalm
Hi All, I have a mac and have put a media source in OBS. The video plays fine and I now want to livestream to facebook. This works great except it doesn't play sound on the stream? Any help would be most useful. Audio advanced is set to Monitor only more output? THANKS!
RichieTee
You need to set Advanced Audio to "Monitor and Output".
RichieTee
You're a legend. If I could buy you a beer I would. Is this same for zoom calls too? If I put zoom into OBS then stream?
Not exactly, for Zoom to OBS you need a few steps
Assumption: Zoom is providing the audio and video for OBS.
1. How are you capturing your Zoom Video Feed? Most people will use Windows Capture (if you have or do not have an external monitor) or Display Capture (if you have an external monitor).
2. How are you capturing your Zoom Audio? Often you need some sort of virtual cable or audio device.
Check out my blog on how to do that. If you have further questions let me know.
