loswedgies
I'm brand new to OBS Studio. I'm trying to get things working. The video stuff is fine - I can record input from my camera and I can record actions on the computer screen. But I am having problems with audio - both inputs and outputs. I can't record mic input or speaker output.
I have a Tascam US-1800 interface. It works fine everywhere else on my computer except OBS Studio. I use the Reaper DAW, for example, and the Tascam has always worked fine there. But in OBS Studio, when I go to select the Tascam in "Audio Input Capture" there is no sound coming in. There is no signal on the level meter. As a test I selected the mic on my Brio camera and I *do* get audio levels. But the Brio's sound is pretty bad so I want to use the Tascam. And anyway that wouldn't solve my problem of not being able to record speaker output.
One thing I don't understand is why there is only one input available for the Tascam. It has 14 audio inputs. Reaper, for example, gives me the choice of all 14 inputs. But OBS Studio has one Tascam input option: "Line In (TASCAM US-1800)". How does OBS know which input I have my mic plugged into?
I've tried reading a bunch of advice. I've reinstalled the Tascam drivers. But nothing has worked yet. Anyway, I'd be appreciative if someone could help me with the problem.
Thanks!
Thanks!
