Question / Help HELP SETTING UP BEST STREAM SETTINGS FOR WOW
rukadar
hey i am really new and very ignorant to streaming i don't know much about it at all. So i am looking for some help on the best settings for my stream. Thank you.
For twitch:
Ouput Tab
I included both simple and Advanced but I'd recommend using simple.
Simple output mode
Bitrate 3000
Encoder x264
Audio Bitrate 160
Enable Advanced enocder settings Checked
Encoder Preset Faster
Advanced output mode (Not recommended)
Encoder x264
Rate Control CBR
Bitrate 3000
Keyframe interval 2
CPU preset faster
profile main
video tab
Base resolution 1920x1080
Output resolution 1280x720
Downscale filter Lanczos
Framerate 30 (or 60)
if you are not streaming to twitch tell me where you are streaming to.
I also uploaded a picture if it is easier for you to copy settings that way.
