Hey all - I have OBS downloaded and running as administrator, but still can't get anything to record other than a black screen. I have read multiple posts with suggestions and tried several different settings both on my computer and OBS. I am absolutely helpless when it comes to PC stuff... Please take a look at my log below and let me know how I can get recording (or if that's possible).
12:09:45.274: CoInitializeEx succeeded: 0x00000001
12:09:45.274: CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
12:09:45.274: CPU Speed: 3392MHz
12:09:45.274: Physical Cores: 4, Logical Cores: 4
12:09:45.274: Physical Memory: 8162MB Total, 2695MB Free
12:09:45.274: Windows Version: 6.1 Build 7601 (release: unavailable; revision: 24545; 64-bit)
12:09:45.274: Running as administrator: true
12:09:45.274: Aero is Enabled
12:09:45.276: Current Date/Time: 2020-09-13, 12:09:45
12:09:45.276: Browser Hardware Acceleration: false
12:09:45.276: Portable mode: false
12:09:45.823: OBS 25.0.8 (64-bit, windows)
12:09:45.823: ---------------------------------
12:09:45.824: ---------------------------------
12:09:45.824: audio settings reset:
12:09:45.824: samples per sec: 44100
12:09:45.824: speakers: 2
12:09:45.827: ---------------------------------
12:09:45.827: Initializing D3D11...
12:09:45.827: Available Video Adapters:
12:09:45.829: Adapter 0: NVIDIA GeForce GT 720
12:09:45.829: Dedicated VRAM: 1009778688
12:09:45.829: Shared VRAM: 3221549056
12:09:45.829: PCI ID: 10de:1288
12:09:45.830: Driver Version: 25.21.14.1735
12:09:45.830: output 0: pos={0, 0}, size={1280, 1024}, attached=true, refresh=60, name=SyncMaster
12:09:45.833: Loading up D3D11 on adapter NVIDIA GeForce GT 720 (0)
12:09:45.879: D3D11 loaded successfully, feature level used: b000
12:09:45.879: DXGI increase maximum frame latency success
12:09:45.879: D3D11 GPU priority setup failed (not admin?)
12:09:46.657: ---------------------------------
12:09:46.657: video settings reset:
12:09:46.657: base resolution: 1280x1024
12:09:46.657: output resolution: 1280x1024
12:09:46.657: downscale filter: Bicubic
12:09:46.657: fps: 60/1
12:09:46.657: format: NV12
12:09:46.657: YUV mode: 601/Partial
12:09:46.658: NV12 texture support not available
12:09:46.660: Audio monitoring device:
12:09:46.660: name: Default
12:09:46.660: id: default
12:09:46.660: ---------------------------------
12:09:46.676: [CoreAudio encoder]: Adding CoreAudio AAC encoder
12:09:46.678: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
12:09:46.750: [AMF] Unable to load 'amfrt64.dll', error code 126.
12:09:46.754: [AMF] AMF Test failed due to one or more errors.
12:09:46.754: Failed to initialize module 'enc-amf.dll'
12:09:46.795: [obs-browser]: Version 2.8.6
12:09:46.803: NVENC supported
12:09:46.932: Couldn't find VLC installation, VLC video source disabled
12:09:46.956: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
12:09:46.956: No blackmagic support
12:09:46.962: ---------------------------------
12:09:46.962: Loaded Modules:
12:09:46.962: win-wasapi.dll
12:09:46.962: win-mf.dll
12:09:46.962: win-dshow.dll
12:09:46.962: win-decklink.dll
12:09:46.962: win-capture.dll
12:09:46.963: vlc-video.dll
12:09:46.963: text-freetype2.dll
12:09:46.963: rtmp-services.dll
12:09:46.963: obs-x264.dll
12:09:46.963: obs-vst.dll
12:09:46.963: obs-transitions.dll
12:09:46.963: obs-text.dll
12:09:46.963: obs-qsv11.dll
12:09:46.963: obs-outputs.dll
12:09:46.963: obs-filters.dll
12:09:46.963: obs-ffmpeg.dll
12:09:46.963: obs-browser.dll
12:09:46.963: image-source.dll
12:09:46.963: frontend-tools.dll
12:09:46.963: enc-amf.dll
12:09:46.963: decklink-ouput-ui.dll
12:09:46.963: coreaudio-encoder.dll
12:09:46.963: ---------------------------------
12:09:46.963: ==== Startup complete ===============================================
12:09:47.001: Service '' not found
12:09:47.017: All scene data cleared
12:09:47.017: ------------------------------------------------
12:09:47.062: WASAPI: Device 'Speakers (Conexant HD Audio)' [192000 Hz] initialized
12:09:47.062: [Loaded global audio device]: 'Desktop Audio'
12:09:47.114: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Desktop Audio)
12:09:47.114:
12:09:48.358: Switched to scene 'Scene'
12:09:48.358: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:48.360: [game-capture: 'Sims 4'] capture stopped
12:09:48.361: ------------------------------------------------
12:09:48.361: Loaded scenes:
12:09:48.361: - scene 'Scene':
12:09:48.361: - source: 'Sims 4' (game_capture)
12:09:50.361: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:50.378: [game-capture: 'Sims 4'] capture stopped
12:09:51.827: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:51.844: [game-capture: 'Sims 4'] capture stopped
12:09:53.844: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:53.861: [game-capture: 'Sims 4'] capture stopped
12:09:55.860: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:55.877: [game-capture: 'Sims 4'] capture stopped
12:09:57.877: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:57.894: [game-capture: 'Sims 4'] capture stopped
12:09:59.894: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:09:59.910: [game-capture: 'Sims 4'] capture stopped
12:10:01.910: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:01.927: [game-capture: 'Sims 4'] capture stopped
12:10:03.927: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:03.944: [game-capture: 'Sims 4'] capture stopped
12:10:05.943: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:05.960: [game-capture: 'Sims 4'] capture stopped
12:10:07.961: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:07.978: [game-capture: 'Sims 4'] capture stopped
12:10:09.978: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:09.994: [game-capture: 'Sims 4'] capture stopped
12:10:11.994: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:12.011: [game-capture: 'Sims 4'] capture stopped
12:10:14.011: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:14.028: [game-capture: 'Sims 4'] capture stopped
12:10:16.027: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:16.044: [game-capture: 'Sims 4'] capture stopped
12:10:18.044: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:18.061: [game-capture: 'Sims 4'] capture stopped
12:10:20.060: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:20.077: [game-capture: 'Sims 4'] capture stopped
12:10:22.077: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:22.094: [game-capture: 'Sims 4'] capture stopped
12:10:24.095: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:24.112: [game-capture: 'Sims 4'] capture stopped
12:10:26.111: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:26.128: [game-capture: 'Sims 4'] capture stopped
12:10:28.128: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:28.145: [game-capture: 'Sims 4'] capture stopped
12:10:30.144: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:30.161: [game-capture: 'Sims 4'] capture stopped
12:10:32.161: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:32.178: [game-capture: 'Sims 4'] capture stopped
12:10:34.178: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:34.195: [game-capture: 'Sims 4'] capture stopped
12:10:36.194: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:36.211: [game-capture: 'Sims 4'] capture stopped
12:10:38.211: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:38.228: [game-capture: 'Sims 4'] capture stopped
12:10:40.227: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:40.244: [game-capture: 'Sims 4'] capture stopped
12:10:42.245: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:42.262: [game-capture: 'Sims 4'] capture stopped
12:10:44.261: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:44.278: [game-capture: 'Sims 4'] capture stopped
12:10:46.278: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:46.295: [game-capture: 'Sims 4'] capture stopped
12:10:48.295: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:48.312: [game-capture: 'Sims 4'] capture stopped
12:10:50.311: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:50.328: [game-capture: 'Sims 4'] capture stopped
12:10:52.328: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:52.345: [game-capture: 'Sims 4'] capture stopped
12:10:54.344: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:54.361: [game-capture: 'Sims 4'] capture stopped
12:10:56.361: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:56.378: [game-capture: 'Sims 4'] capture stopped
12:10:58.378: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:10:58.395: [game-capture: 'Sims 4'] capture stopped
12:11:00.395: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:00.412: [game-capture: 'Sims 4'] capture stopped
12:11:02.412: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:02.429: [game-capture: 'Sims 4'] capture stopped
12:11:04.428: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:04.445: [game-capture: 'Sims 4'] capture stopped
12:11:06.445: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:06.462: [game-capture: 'Sims 4'] capture stopped
12:11:08.461: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:08.478: [game-capture: 'Sims 4'] capture stopped
12:11:10.478: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:10.495: [game-capture: 'Sims 4'] capture stopped
12:11:12.495: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:12.512: [game-capture: 'Sims 4'] capture stopped
12:11:14.511: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:14.528: [game-capture: 'Sims 4'] capture stopped
12:11:16.529: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:16.546: [game-capture: 'Sims 4'] capture stopped
12:11:18.545: [game-capture: 'Sims 4'] attempting to hook process: TS4_x64.exe
12:11:18.562: [game-capture: 'Sims 4'] capture stopped
12:09:47.114:
