Hey everyone,
So, I got my Elgato HD60 about two months ago, and it's been working fine in OBS ever since. I went to use it today, and when I opened OBS and I was about to start streaming, I noticed my video quality was terrible. My video quality is blurry and distorted and I don't know how to get it back to looking nice and crisp. The words are especially terrible looking. Completely illegible.
Does anyone know how to fix this?!
20:04:50.767: CPU Name: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
20:04:50.767: CPU Speed: 2394MHz
20:04:50.767: Physical Cores: 2, Logical Cores: 4
20:04:50.767: Physical Memory: 8107MB Total, 6084MB Free
20:04:50.767: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
20:04:50.767: Running as administrator: false
20:04:50.767: Aero is Enabled (Aero is always on for windows 8 and above)
20:04:50.767: Portable mode: false
20:04:50.775: OBS 17.0.2 (64bit, windows)
20:04:50.775: ---------------------------------
20:04:50.776: ---------------------------------
20:04:50.776: audio settings reset:
20:04:50.776: samples per sec: 44100
20:04:50.776: speakers: 2
20:04:50.778: ---------------------------------
20:04:50.778: Initializing D3D11..
20:04:50.778: Available Video Adapters:
20:04:50.779: Adapter 1: Intel(R) HD Graphics 5500
20:04:50.779: Dedicated VRAM: 134217728
20:04:50.779: Shared VRAM: 4250443776
20:04:50.779: output 1: pos={0, 0}, size={1366, 768}, attached=true
20:04:50.781: Loading up D3D11 on adapter Intel(R) HD Graphics 5500 (0)
20:04:50.786: D3D11 loaded sucessfully, feature level used: 45056
20:04:51.334: ---------------------------------
20:04:51.334: video settings reset:
20:04:51.334: base resolution: 1920x1018
20:04:51.334: output resolution: 1280x678
20:04:51.334: downscale filter: Bicubic
20:04:51.334: fps: 30/1
20:04:51.334: format: NV12
20:04:51.335: ---------------------------------
20:04:51.336: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
20:04:51.337: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:04:51.338: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
20:04:51.350: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
20:04:51.351: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
20:04:51.351: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
20:04:51.351: Failed to load 'en-US' text for module: 'obs-browser.dll'
20:04:51.351: [browser_source: 'Version: 1.28.0']
20:04:51.352: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
20:04:51.352: (126)
20:04:51.362: Couldn't find VLC installation, VLC video source disabled
20:04:51.371: No blackmagic support
20:04:51.601: ---------------------------------
20:04:51.601: Loaded Modules:
20:04:51.601: win-wasapi.dll
20:04:51.601: win-mf.dll
20:04:51.601: win-dshow.dll
20:04:51.601: win-decklink.dll
20:04:51.601: win-capture.dll
20:04:51.601: vlc-video.dll
20:04:51.602: text-freetype2.dll
20:04:51.602: rtmp-services.dll
20:04:51.602: obs-x264.dll
20:04:51.602: obs-transitions.dll
20:04:51.602: obs-text.dll
20:04:51.602: obs-qsv11.dll
20:04:51.602: obs-outputs.dll
20:04:51.602: obs-filters.dll
20:04:51.602: obs-ffmpeg.dll
20:04:51.602: obs-browser.dll
20:04:51.602: image-source.dll
20:04:51.602: frontend-tools.dll
20:04:51.602: enc-amf.dll
20:04:51.602: coreaudio-encoder.dll
20:04:51.602: ==== Startup complete ===============================================
20:04:51.605: All scene data cleared
20:04:51.605: ------------------------------------------------
20:04:51.611: [WASAPISource::TryInitialize]:[Speakers (Yeti Stereo Microphone)] Failed to activate client context: 88890004
20:04:51.611: [WASAPISource::WASAPISource] Device '{0.0.0.00000000}.{e9562c17-5d05-4c81-8bc5-89fd13274ebe}' not found. Waiting for device
20:04:51.765: [WASAPISource::TryInitialize]:[Microphone (Yeti Stereo Microphone)] Failed to activate client context: 88890004
20:04:51.765: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{f7f5112e-e2ee-40f6-b790-6bd7223f6f89}' not found. Waiting for device
20:04:51.810: Switched to scene 'Gameplay'
20:04:51.810: ------------------------------------------------
20:04:51.811: Loaded scenes:
20:04:51.811: - scene 'Gameplay':
20:04:51.811: - source: 'Elgato' (dshow_input)
20:04:51.811: - source: 'Follow / Donation' (browser_source)
20:04:51.811: - source: 'Yeti' (wasapi_input_capture)
20:04:51.811: - filter: 'Noise Suppression' (noise_suppress_filter)
20:04:51.811: - source: 'Overlay' (image_source)
20:04:51.812: - source: 'Recent Donator' (text_ft2_source)
20:04:51.812: - source: 'Rec. Follower' (text_gdiplus)
20:04:51.812: - source: 'Social Pop' (browser_source)
20:04:51.812: - source: 'Web Cam' (dshow_input)
20:04:51.812: - filter: 'Video Delay (Async)' (async_delay_filter)
20:04:51.812: ------------------------------------------------
20:04:51.952: Update check: last known remote version is 17.0.2
20:04:52.072: ---------------------------------
20:04:52.072: [DShow Device: 'Web Cam'] settings updated:
20:04:52.072: video device: Lenovo EasyCamera
20:04:52.072: video path: \\?\usb#vid_13d3&pid_5727&mi_00#6&aefad6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
20:04:52.072: resolution: 640x480
20:04:52.072: fps: 30.00 (interval: 333333)
20:04:52.072: format: YUY2
20:04:54.482: ---------------------------------
20:04:54.482: [DShow Device: 'Elgato'] settings updated:
20:04:54.482: video device: Elgato Game Capture HD
20:04:54.482: video path: __elgato
20:04:54.482: resolution: 640x480
20:04:54.482: fps: 30.00 (interval: 333333)
20:04:54.482: format: UYVY
20:04:54.482: using video device audio: yes
20:04:54.482: sample rate: 48000
20:04:54.482: channels: 2
20:04:54.482: audio type: Capture
20:06:28.135: ---------------------------------
20:06:28.136: video settings reset:
20:06:28.136: base resolution: 1280x720
20:06:28.136: output resolution: 1280x720
20:06:28.136: downscale filter: Bicubic
20:06:28.136: fps: 30/1
20:06:28.136: format: NV12
20:06:28.141: Settings changed (outputs, video)
20:06:28.141: ------------------------------------------------
20:04:51.352: (126)
