johnny silver
ok so i have tried everything i can think of to solve this issue when i stream after about 5 minutes my connection will go from green to red reaching 0kbps then back to green i have a good computer and have learned a lot about streaming but cant figure this out i never reach 100% cpu usage it stays around 9% i stream at 1920x1080 down-scaled to 1280X720 with 3000 bit-rate and have tried streaming to every server available with the same issues i have tried dropping the bitrate as well i have also tested my upload and its around 13 mbps on average and i have contacted my isp comcast to ask about throttling but they said that everything was fine i aslo read to put your PC in DMZ and did that with no luck i have upgraded all my network drivers as well heres a log of my last stream if this helps
