it sound like I hear song behind wall or something , a bit echo or idk ,or like sound is a bit lowered -10 db. or idk I cant describe listen and you will know
this happens to me while recording gameplay or in windows same problem
I use kraken 7.1 headset
here is sample
https://vid.me/AK6E
original song
https://youtu.be/btPJPFnesV4?t=1m50s
do you hear difference , can anyone help me pls :( and thank you
HERE IS LOG
21:45:27.575: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
21:45:27.575: CPU Speed: 3293MHz
21:45:27.575: Physical Cores: 4, Logical Cores: 4
21:45:27.575: Physical Memory: 8152MB Total, 3677MB Free
21:45:27.575: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
21:45:27.575: Running as administrator: false
21:45:27.575: Aero is Enabled (Aero is always on for windows 8 and above)
21:45:27.576: Portable mode: false
21:45:27.591: OBS 17.0.0 (64bit, windows)
21:45:27.591: ---------------------------------
21:45:27.592: ---------------------------------
21:45:27.592: audio settings reset:
21:45:27.592: samples per sec: 48000
21:45:27.592: speakers: 2
21:45:27.604: ---------------------------------
21:45:27.604: Initializing D3D11..
21:45:27.604: Available Video Adapters:
21:45:27.606: Adapter 1: NVIDIA GeForce GTX 960
21:45:27.606: Dedicated VRAM: 2114650112
21:45:27.606: Shared VRAM: 4274419712
21:45:27.606: output 1: pos={0, 0}, size={1280, 1024}, attached=true
21:45:27.610: Loading up D3D11 on adapter NVIDIA GeForce GTX 960 (0)
21:45:28.114: D3D11 loaded sucessfully, feature level used: 45056
21:45:28.647: ---------------------------------
21:45:28.647: video settings reset:
21:45:28.647: base resolution: 1280x1024
21:45:28.647: output resolution: 1280x720
21:45:28.647: downscale filter: Lanczos
21:45:28.647: fps: 60/1
21:45:28.647: format: NV12
21:45:28.649: ---------------------------------
21:45:28.661: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:45:28.680: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
21:45:28.681: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
21:45:29.134: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
21:45:29.141: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
21:45:29.180: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
21:45:29.193: Failed to load 'en-US' text for module: 'obs-browser.dll'
21:45:29.193: [browser_source: 'Version: 1.27.0']
21:45:29.227: NVENC supported
21:45:29.404: Couldn't find VLC installation, VLC video source disabled
21:45:29.427: No blackmagic support
21:45:29.601: ---------------------------------
21:45:29.601: Loaded Modules:
21:45:29.601: win-wasapi.dll
21:45:29.601: win-mf.dll
21:45:29.601: win-dshow.dll
21:45:29.601: win-decklink.dll
21:45:29.601: win-capture.dll
21:45:29.601: vlc-video.dll
21:45:29.601: text-freetype2.dll
21:45:29.601: rtmp-services.dll
21:45:29.601: obs-x264.dll
21:45:29.601: obs-transitions.dll
21:45:29.601: obs-text.dll
21:45:29.601: obs-qsv11.dll
21:45:29.601: obs-outputs.dll
21:45:29.601: obs-filters.dll
21:45:29.601: obs-ffmpeg.dll
21:45:29.601: obs-browser.dll
21:45:29.601: image-source.dll
21:45:29.601: frontend-tools.dll
21:45:29.601: enc-amf.dll
21:45:29.601: coreaudio-encoder.dll
21:45:29.601: ==== Startup complete ===============================================
21:45:29.606: All scene data cleared
21:45:29.606: ------------------------------------------------
21:45:29.660: WASAPI: Device 'Headset Earphone (4- Razer Kraken 7.1 Chroma)' initialized
21:45:29.661: [WASAPISource::TryInitialize]:[Headset Microphone (3- Razer Kraken 7.1 Chroma)] Failed to activate client context: 88890004
21:45:29.661: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{804f9bdc-eba4-4f34-8427-9fa6642b026a}' not found. Waiting for device
21:45:29.688: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds
21:45:32.554: Switched to scene 'Scene'
21:45:32.555: ------------------------------------------------
21:45:32.555: Loaded scenes:
21:45:32.555: - scene 'Scene':
21:45:32.555: - source: 'Game Capture' (game_capture)
21:45:37.759: User added source 'Display Capture' (monitor_capture) to scene 'Scene'
21:46:13.222: ---------------------------------
21:46:13.222: video settings reset:
21:46:13.222: base resolution: 1280x1024
21:46:13.222: output resolution: 1280x720
21:46:13.222: downscale filter: Lanczos
21:46:13.222: fps: 60/1
21:46:13.222: format: NV12
21:46:13.228: Settings changed (outputs, video)
21:46:13.228: ------------------------------------------------
21:46:16.642: ---------------------------------
21:46:16.643: [NVENC encoder: 'streaming_h264'] settings:
21:46:16.643: rate_control: CBR
21:46:16.643: bitrate: 3500
21:46:16.643: cqp: 0
21:46:16.643: keyint: 120
21:46:16.643: preset: hq
21:46:16.643: profile: main
21:46:16.643: level: auto
21:46:16.643: width: 1280
21:46:16.643: height: 1024
21:46:16.643: 2-pass: true
21:46:16.643: b-frames: 2
21:46:16.643: GPU: 0
21:46:16.643:
21:46:17.381: [Media Foundation AAC: 'Track1']: encoder created
21:46:17.381: bitrate: 128
21:46:17.381: channels: 2
21:46:17.381: sample rate: 48000
21:46:17.381: bits-per-sample: 16
21:46:17.381:
21:46:17.472: ==== Recording Start ===============================================
21:46:17.472: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/REC YT/2017-02-24 21-46-16.mp4'...
21:46:30.198: [ffmpeg muxer: 'adv_file_output'] Output of file 'D:/REC YT/2017-02-24 21-46-16.mp4' stopped
21:46:30.198: Output 'adv_file_output': stopping
21:46:30.198: Output 'adv_file_output': Total encoded frames: 0
21:46:30.198: Output 'adv_file_output': Total drawn frames: 763
21:46:30.198: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 10 (1.3%)
21:46:30.199: ==== Recording Stop ================================================
21:47:07.076: ---------------------------------
21:47:07.076: video settings reset:
21:47:07.076: base resolution: 1280x1024
21:47:07.076: output resolution: 1280x720
21:47:07.076: downscale filter: Lanczos
21:47:07.076: fps: 60/1
21:47:07.076: format: NV12
21:47:07.082: Settings changed (outputs, video)
21:47:07.082: ------------------------------------------------
21:47:16.469: ---------------------------------
21:47:16.469: [NVENC encoder: 'streaming_h264'] settings:
21:47:16.469: rate_control: CBR
21:47:16.469: bitrate: 3500
21:47:16.469: cqp: 0
21:47:16.469: keyint: 120
21:47:16.469: preset: hq
21:47:16.469: profile: main
21:47:16.469: level: auto
21:47:16.469: width: 1280
21:47:16.469: height: 1024
21:47:16.469: 2-pass: true
21:47:16.469: b-frames: 2
21:47:16.469: GPU: 0
21:47:16.469:
21:47:16.743: ---------------------------------
21:47:16.743: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2
21:47:16.758: ==== Recording Start ===============================================
21:47:16.758: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/REC YT/2017-02-24 21-47-16.mp4'...
21:47:26.702: [ffmpeg muxer: 'adv_file_output'] Output of file 'D:/REC YT/2017-02-24 21-47-16.mp4' stopped
21:47:26.702: Output 'adv_file_output': stopping
21:47:26.702: Output 'adv_file_output': Total encoded frames: 0
21:47:26.702: Output 'adv_file_output': Total drawn frames: 598
21:47:26.702: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 4 (0.7%)
21:47:26.703: ==== Recording Stop ================================================
21:47:58.141: ---------------------------------
21:47:58.141: [NVENC encoder: 'streaming_h264'] settings:
21:47:58.141: rate_control: CBR
21:47:58.141: bitrate: 3500
21:47:58.141: cqp: 0
21:47:58.141: keyint: 120
21:47:58.141: preset: hq
21:47:58.141: profile: main
21:47:58.141: level: auto
21:47:58.141: width: 1280
21:47:58.141: height: 1024
21:47:58.141: 2-pass: true
21:47:58.141: b-frames: 2
21:47:58.141: GPU: 0
21:47:58.141:
21:47:58.410: ---------------------------------
21:47:58.410: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2
21:47:58.424: ==== Recording Start ===============================================
21:47:58.424: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/REC YT/2017-02-24 21-47-58.mp4'...
21:48:15.112: [ffmpeg muxer: 'adv_file_output'] Output of file 'D:/REC YT/2017-02-24 21-47-58.mp4' stopped
21:48:15.112: Output 'adv_file_output': stopping
21:48:15.112: Output 'adv_file_output': Total encoded frames: 0
21:48:15.112: Output 'adv_file_output': Total drawn frames: 999
21:48:15.112: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 3 (0.3%)
21:48:15.112: ==== Recording Stop ================================================
21:51:03.227: ---------------------------------
here is sample
https://vid.me/AK6E
original song
HERE IS LOG
21:46:16.643:
21:46:17.381:
21:47:16.469:
21:47:58.141:
