jeremyb777
Hi,
I am working with a very simple set up. I have a laptop with built in camera and microphone. I use OBS with virtual cam to control what I send to Zoom. No problems on the video. I also use a virtual audio cable to connect OBS to zoom through the monitor output. Within OBS, I have solved all sync problems using the Audio sync offset options in the Advanced Audio Settings. However, it appears that these audio sync offsets do not apply to the monitor. Therefore, the audio sent to Zoom is still quite out of sync. I had this working about perfectly before my hard drive crashed, but now I just can't get it right.
If I record within Zoom, the audio is perfectly synced. If I stream to Facebook, it is perfectly synced. However, the problem seems to be sending the audio from OBS to Zoom through the monitor (virtual cable). I have seen some comments from people that seem to have fixed this by using Voicemeeter. However, I am quite uncertain as to how to do this. All of this stuff is a bit over my head, so I might need fairly detailed instructions. Any help would be appreciated.
One last thing, I am not concerned about having what happens in Zoom brought into OBS... I would prefer that what happens in the Zoom window NOT be shared in the Facebook stream. In other words, I am only concerned about getting my audio correctly sent from OBS to Zoom without having the audio sync problems. I mostly just use a Microphone and various videos through VLC and I have the VLC audio sync offset set to around 200 which sounds perfect... just not on Zoom. Thank you!
