C3ns1o
Hallo, i have buy a HDR 1000 Monitor and want play in HDR but Stream in SDR.
So i have try many thinks as LUT, Color Corection ....
I have try Windows 11 and some other Software that can Handel Ton Mapping....
Well done.. OBS is and will be the only one i thnik to use for Streaming.
No i have some Problems after i put my Windows 10 Backup back on disk.
When i use DXGI Capture (Duplicate Windows) its stutter. And yes.. i have chose low energy for the app.
When i turn HDR of DXGI works normal... when i put HDR on again, it works some times so long, i close OBS and start new... thatwas not bevor.
When i let the Display Capture on Windows 10 1902 i get ugly glitches in stream and rubberbands but preview seems well.
So i thnik to buy a Capture Card that they do Tone Mapping vor me and still the Capture Problems goes away
I think 4k GC573 or $K60 Pro MK2
But i can not find if the AVerMedia has Multi Devices. So i use two OBS to stream on twitch with 1080p and to others with 1440p.
My PC is as follow:
Ryzen 9 5950x
32 DDR4 3800
AMD 6900XT
TechN and Byksi Watercooling
HDR 1000 Monitor at 1440p @ 144Hz
Thanks for help!!!
My PC is as follow:
Ryzen 9 5950x
32 DDR4 3800
AMD 6900XT
Thanks for help!!!
