Games run horribly with OBS + Max Audio Buffering issue
anarhistabg
I don't know if it's important, but I'll share anyway. I play on 3070 + 12700k, Windows 10, 240hz monitor.
I have the following problem: when I play any game without OBS running, everything runs fine.
Example: if I play Apex Legends, Valorant, Sea of Thieves at 240 fps, everything is great! The picture is very smooth.
When I launch OBS and start streaming, things change. Again, I have 240 fps in the listed games, BUT the game itself runs badly... It feels like I'm playing at 100 fps (instead of 240), the game itself lags, there is screen tearing when moving the mouse, etc. In short: the game itself runs great without OBS and very poorly with OBS.
I refuse to believe that my setup is weak because I used to play and stream from 1070 and 7700K when I was with my old PC.
I tried with different NVENC encoder settings ( lower and higher ) = same result. Tried streaming with x264 encoder = same result. Tried with GPU Acceleration on and off = same result.
This is the LOG file from my last stream: https://obsproject.com/logs/taafJdWj9qCQC3Kd
Browser Not Accelerated - it doesn't matter as i said...
Capture Interference - it doesn't matter, because I've had this problem for 2 months, and I added a scene with monitor and game capture 2 days ago.
CRITICAL: Max Audio Buffering - I don't know what this is, I don't know if it has anything to do with my problem
Greetings!
