BatmansOBS
Windows 10
Focusrite 18i/20 (Focusrite Control software)
Cubase 10
AT2020 microphone with phantom power.
I have no problem hearing the microphone through Cubase 10 if I use the ASIO Focusrite driver and add the channel with the microphone plugged in through the XLR port behind on input 6.
As you can see there are levels in Analogue 6 so it's recognizing the mic.
I add an Audio Input Capture for the Focusrite.
However there is no sound coming through on the levels in OBS at all. I tried to select Mono also. I am unsure what else I need to do.
I am unsure what I need to do to get this working. It would be great to be able to record audio this way instead of using Cubase and then syncing up in post production with a video editor. I could also use OBS live with it.
Also the following tutorial did not help my problem either. Maybe I am doing something wrong?
support.focusrite.com
Pls help. Thanks.
Cubase 10
How to set up your audio interface in OBS (Open Broadcaster Software) on Windows
Applies to: All Focusrite audio interfaces This is a guide to setting up your audio interface in Open Broadcaster Software (OBS) on Windows. For instructions for Mac, please see the following artic...
Pls help. Thanks.
