Hello everyone
We're doing our first live DJ stream tomorrow on Facebook. We're new to this and need some assistance.
2 Logitech C920 cameras will be used for the video, with an image overlay. The sound will be fed into the PC using the Line In on the soundcard. The cameras will be alternated manually during the stream.
Do I need to create 2 scenes, or can 1 scene be used (and simply turn the visibility of the one on/off when required).
If 2 scenes need to be created, how do you use the same audio for both scenes?
I'm also planning on using Speedify software to merge 2 internet lines to avoid any drops. Has anyone used this before?
Some of the other settings:
Encoder x264
Rate Control CBR
Bitrate 2500
Keyframe Interval 2
CPU Usage Preset veryfast
Audio Bitrate 128
Base Canvas Resolution 1280x720
Output Scaled Resolution 1280x720
Downscale Filter Bicubic
Commons FPS Values 30
Thanks in advance!
Encoder x264
Rate Control CBR
Bitrate 2500
Keyframe Interval 2
Audio Bitrate 128
Thanks in advance!
