[Feature Request] - LPCM/Raw PCM audio capture, and expand on audio options in general.
Magus
I think it'd be quite nice to have LPCM as a choosable audio format.
Currently we're quite restricted in terms of audio capture choices. By what I can tell you have no choice in audio format and the bitrate remains at 160 even if you choose a higher bitrate in the options. So... basically your only choice is 16-bit AAC 160kbps at 44.1 or 48KHz.
I'd love to see far more control in the audio department. AAC should just be one of the available formats - MP3, Opus, and LPCM at least should also be available.
For more info on the audio bitrate bug - it occurs when using "Output Mode - Advanced".
Thanks.
