Question / Help Extreme audio problems with Avermedia CaptureCard GC550
Yasaka
hi, i have a LiveGamerExtreme and the card worked fine for like 1 year. last month i updated the driver and since then i have really annoying problems with the sound of it. at the beginning it was just a little cracking noise sometimes. i used waveout in obs to hear the gamesound on my pc.
i switched to directsound and the problem was gone. but another problem appeared, sometimes the sound disappeared and after a few seconds there was sound again but desynced. and since like 1-2 days i have really big problems with it.
weither i use waveout or directsound it doesnt matter i have audio cracking all the time. in waveout the audio sometimes goes away like in directsound but doesnt desync. i tried a lot of things like using older drivers or using a different usb port but nothing helped.
the problem only occurs when the capturecards signal is 1080p. when i have my wii connected with 480p everything is fine. the problem also occurs in the recentral software. with the video signal however everything is fine. always smooth 60fps.
here is a log file https://hastebin.com/numacageri
