I have been dealing with a issue now for months where mid stream whether its 5 min in or 2 hours in the bit rate will start to drop and then my stream will completely drop to 0 and it will shut off and try to reconnect
I have just started really getting followers and donations so this has really been a pain.
Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
CPU Speed: 3503MHz
Physical Cores: 4, Logical Cores: 8
NVIDIA GeForce GTX 590
AVerMedia HD Capture C985 connected to ps4 pro
my internet is Comcast 250 down 30 up
Things I have done to try and fix it.
had a tech come out multiple times to check bandwidth
switched to my own 200 dollar netgear modem and 1900 router
completely got rid of windows 7 that I was using and did a format and fresh install of windows ten
went to obs windows and avermedia to make sure I wasn't missing drivers
dropped my bitrate to 1500 and issue still happens. Tried to play games both on pc or on the ps4 to see if its just the
capture card or the video card ....in the end my stream still drops I have posted some logs from last night please help.
CPU Speed: 3503MHz
