Double mic input in OBS using evo4 audio interface
pablocoutto
Hi, I can't use properly the evo4 audio interface with OBS. I mean, I use Adobe Audition for vocal processing and when it comes to streaming and picking up the input source in OBS I can only choose evo4, and this gets the audio from the loopback and ALSO the input directly from the mic, so in the end it is getting the loopback sound but also the mono input from the microphone. How can I mute the input from the microphone and still being able to use it via Adobe Audition and only getting the loopback through OBS? I want to use it for live streaming performances, so I don't want to add any other software that could increase latency.
Thanks
Hey there,
I'm having the exact same problem. I've had multiple kicks at the can over the past 12 months but still haven't been able to prevent the mono mic input from going out on my livestreams with the loopback output. It seems that channels 1/2 and 3/4 are treated discreetly in Windows but not so on Mac. Hoping that someone has figured this issue out.
Thank you!
