Question / Help Does Studio have the bottom right corner connection indicator box?
JeffsOn
The little box that goes from Green to yellow to red to indicate your connection stability that sits in the bottom right corner. I used it all the time to check small flickers and instability in regular OBS to see if my connection was even slightly unstable even if it's not actually dropping frames or disconnecting. In Studio, I dont see this box and I was wondering if Studio has the option to enable it or if there's another indicator to let me know if my connection is dropping out or beginning to drop out at any point where that other indicator is or what my other options are to have an live stability indicator that's measured in a similar way.
Thanks for any help.
Suslik V
By now, OBS Studio doesn't have custom icon support (per event or per state). Only recording indicator implemented (fixed size icon), small red circle over OBS tray icon.
Edit: Network indicator was introduced in OBS Studio v18.0.0
