Desperate for help, OBS disconnecting/reconnecting issue
RDUB56
Hi there,
For two years I've streamed without any real problems. Things would disconnect every now and then, but nothing that wasn't manageable. Since September, nearly every stream I find OBS disconnects/reconnects several times. I've tried many things, like updating my drivers, changing the ethernet cable, resetting modem/router, adjusting bitate, rolling back my version of OBS, etc etc. But nothing seems to work. I'm at a complete loss, and this has totally killed my motivation to continue streaming. I'm desperate for some assistance, and any help would be so very much appreciated.
I'll attach a few logs, as every time this happens I make sure to upload a copy. Thank you so much for your time!
PaiSand
Please do review the analyzer. It helps you with common issues.
To better see if your network or the ISP have issues muse this tool:
TwitchTest | r1ch.net
Anything bellow 90 quality is really bad and most probably an issue on the ISP.
And you didn't fully removed the streamFX plugin. Consult on the plugins page and discussion section on how to do it.
RDUB56
Thank you!
I've been digging through the OBS plugin folder, but I can't seem to find anything pertaining to StreamFX. Any suggestions on how I can fully remove it? Thank you again.
