Question / Help Desktop Audio sounds muffled/under water when capturing from USB Headset
Ceeroo
Hello,
when recording in OBS the Audio sounds muffled or as if it was underwater when using my USB headset (Logitech G930); it has been a while since I used OBS but its still the same headset model as back then.
The interesting thing is, if I capture audio through my onboard audiocard everything sounds fine, but of course I can't use my USB headset then.
I tried updating my Logitech drivers, but no luck
My Log File: https://gist.github.com/54677f3112a40c2465e37a9a3f47856e
OBS can only record 2 channel stereo, and you have Logitech G930 which is a 7.1 surround. Try a 2 channel stereo headphone or speakers.
I'm going to bump this thread too. It's really annoying tho I can't track the issue down. Maybe it's the driver? Other 7.1 headsets don't seem to have this issue whatsoever.
Then again other applications such as Audacity can record Desktop Audio just fine, maybe the OBS devs need to change the desktop audio recording backend they're using to something else?
My problem is probably the hardware recognition of the headset microphone (Jabra Evolve, Bluetooth). It is recognized in the audio control as a mono device and thus interferes with the output signal. My Logitech H340 (USB) works fine, the microphone is recognized as stereo. The G930 mentioned at the beginning may be a 7.1 headset, the microphone is certainly also a mono device for Windows. The setting of the "worst" device is often the default for everyone else under Windows. .
