Question / Help Custom Output (FFmpeg) audio track issues.
k1ska
Hello, I'm new to the forums but I have been using OBS for a long time and I'm trying to get my recordings tuned perfectly and everything is working beautifully, however it only allows me to select one track when using Custom Output (FFmpeg). If I use standard recording type, it works as it should and I can select multiple channels. As soon as I switch back to Custom Output, only one can be selected regardless of which audio codec I use. If this is something that can be fixed I would greatly appreciate the help because as it stands, this is the only thing that holds it back from being perfect. :)
Is there anything more going on with this? I would really enjoy having multiple audio channels.
