crash problem with obs: I need help analyzing the error report
shysui
can someone help me pls i really need help ! I crash every stream. Here is the error report. thanks.
  • Crash 2025-09-01 00-11-43.txt
PaiSand
A custom dock or browser source is causing the crash. The most common cause it's a third party plugin. A log file from the moment the crash occurred is needed to see more on this.
shysui
there is the log file can you help me pls ?
  • 2025-08-31 21-34-40.txt
PaiSand
Please review and follow directions and recommendations on the analyzer:
Remove the streamelements browser source (you can add it later) and test it.
Make sure the plugins you have installed are updated and compatible with the OBS version you're using. You can see both installed plugins on the analyzer.
