Question / Help Control Hot Keys using Voice to switch scenes? On Macbook Pro..
Grant P.
I'm a keyboard player and am wanting to stream me playing live. I'm new to OBS but figured out how to use Hot Keys to switch scenes.
i.e. press 1 and Program shows scene 1..... press 2 and Program shows scene 2...
What I'd like to do and I think I'm close here is to Switch scenes by SAYING "1" (instead of pressing 1)... saying "2" instead of pressing 2
I would wear a headset mic (to trigger Hotkeys) while I'm playing that I would not be streaming any audio from. I'm only playing keyboards (no singing or talking)
I found the ability to "Enable Voice Control" on my 2019 16 inch Macbook Pro (Catalina 10.15.4) but am not sure if THAT can be used to SAY "1" and then that would press the 1 key (for scene 1) etc... I enabled it but no luck. Simply saying "1" didn't seem to trigger the OBS hotkey "1"
I'm not wanting to auto switch because I want to be able to select certain cameras for certain parts of the song at that exact time... i.e. closeup on fingers during solo or whatever.
Any ideas would be greatly appreciated! :)
Thank you
