Hi !
I have an issue using obs studio,
In fact i have 2 connections :
Ethernet = LTE Connection = 192.168.0.120 = 192.168.0.1 (gateway) = Streaming connection
Wifi = Adsl connection = 192.168.1.20 = 192.168.1.1 (gateway) = default connection while using for all others apps (for less ping on games !)
I have settings metrics interface to 1 for adsl and 10 (for exemple) to LTE connection
So i have both connection enabled and adsl for standard use.
I try to settings Ethernet IP (LTE) on advanced settings into OBS Studio, but when i try to starting stream it's fail to connect (like to no connection error)
Does windows 10 have specific option to disable to use specific software using specific NIC ?
PS : Can we using Forcebindip with obs studio ? For me it's failed to load
Thanks you a lot for your help !
Best regards.
Romuald.
Best regards.
Romuald.
