Question / Help Capture Card No Audio? Help!
XxBlOoDfAllsxX
So basically as the title says, I have Avermedia Live Gamer Extreme which uses HDMI in/out and USB 3.0, and OBS has no problem adding that to Scenes. I get my Xbox feed no problem, but the issue I'm having is no audio is being recorded locally. Before I state anything, YES I have most recent drivers. OBS is 64bit and so is my Avermedia Driver. The ONLY WAY I can receive audio in my recordings is to put "Audio Output Mode" to "Output Audio Desktop" which is NOT what I want because my sound now comes out through my PC Speakers. I have to mute my PC to record which doesnt allow me to do anything on PC with sound while recording, including listening to music or anything. I have done what everyone has suggested in other posts by clicking on "Use custom audio device" but it only lists my Yeti Mic, and Astro Mixamp. I cant get my Capture card to show up in there either. I have also read to try adding OBS to my Anti-Virus exceptions, done that, still nothing. I have uninstalled OBS multiple times, nothing. I have clicked on "Configure Crossbar and tried those suggestions, still nothing. I cannot for the life of me get "Capture Audio Only" to work. Some help would be greatly appreciated, thank you!
  • 2016-02-27 12-54-52.txt
MissBizz
I'm not using the most recent OBS Studio (I'm using the last OBS MP) but I recall having to install the Avermedia drivers from August in order to make the audio work :) Maybe try that out?
darkangelpt
I have the same problem as you. No audio at all. Really like multiplatform.
But no sound... So bad
Did you Solved the problem already?
