Cant capture Facetime audio using MacOS Screen Capture or Audio Capture sources
samuemx
Hello,
Im having an issue triying to capture the audio from Facetime calls.
This is a fresh installation on a M1. Running Sequoia 15.4.1 and OBS 31.03. When I add the source Mac OS Screen Capture or Mac OS audio capture and selec desktop audio or app audio the sound coming from Facetime does not get captured by OBS (no input on audio mixer). In all others apps (Firefox for example) the desktop audio works as expected.
Do you know if this issue has a fix?
Thank you.
