Question / Help Buzzing Audio Issue on Mic during Stream *HELP!*
stince
Hi team,
I've included a video + log file below!
Trying to get to the bottom of this buzzing noise from my Mic! (Yes i know the video is off by a few miliseconds!)
https://youtu.be/07nSI7EhH8A
09:13:53.721: CPU Name: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
09:13:53.721: CPU Speed: 2496MHz
09:13:53.721: Physical Cores: 4, Logical Cores: 4
09:13:53.721: Physical Memory: 8054MB Total, 5233MB Free
09:13:53.721: Windows Version: 10.0 Build 16299 (revision: 248; 64-bit)
09:13:53.721: Running as administrator: false
09:13:53.721: Aero is Enabled (Aero is always on for windows 8 and above)
09:13:53.722: Windows 10 Gaming Features:
09:13:53.722: Game DVR: On
09:13:53.733: Sec. Software Status:
09:13:53.735: Windows Defender Antivirus: enabled (AV)
09:13:53.736: Windows Firewall: enabled (FW)
09:13:53.772: Windows Defender Antivirus: enabled (ASW)
09:13:53.773: Portable mode: false
09:13:53.824: OBS 21.0.1 (64bit, windows)
09:13:53.824: ---------------------------------
09:13:53.844: ---------------------------------
09:13:53.844: audio settings reset:
09:13:53.844: samples per sec: 44100
09:13:53.844: speakers: 2
09:13:53.846: ---------------------------------
09:13:53.846: Initializing D3D11...
09:13:53.846: Available Video Adapters:
09:13:53.853: Adapter 1: NVIDIA GeForce GTX 1050
09:13:53.853: Dedicated VRAM: 4245684224
09:13:53.853: Shared VRAM: 4222693376
09:13:53.853: output 1: pos={0, 0}, size={1920, 1080}, attached=true
09:13:53.853: Adapter 2: Intel(R) HD Graphics 630
09:13:53.853: Dedicated VRAM: 134217728
09:13:53.857: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 (0)
09:13:54.776: D3D11 loaded successfully, feature level used: 45056
09:13:55.509: ---------------------------------
09:13:55.509: video settings reset:
09:13:55.509: base resolution: 1920x1080
09:13:55.509: output resolution: 1600x900
09:13:55.509: downscale filter: Bicubic
09:13:55.509: fps: 60/1
09:13:55.509: format: NV12
09:13:55.512: Audio monitoring device:
09:13:55.512: name: Default
09:13:55.512: id: default
09:13:55.512: ---------------------------------
09:13:55.513: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
09:13:55.535: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
09:13:55.783: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
09:13:55.784: Failed to initialize module 'enc-amf.dll'
09:13:55.859: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
09:13:55.861: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
09:13:55.864: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
09:13:55.866: Failed to load 'en-US' text for module: 'obs-browser.dll'
09:13:55.866: [browser_source: 'Version: 1.29.0']
09:13:55.879: NVENC supported
09:13:55.939: Couldn't find VLC installation, VLC video source disabled
09:13:55.951: No blackmagic support
09:13:56.683: ---------------------------------
09:13:56.683: Loaded Modules:
09:13:56.683: win-wasapi.dll
09:13:56.683: win-mf.dll
09:13:56.683: win-dshow.dll
09:13:56.683: win-decklink.dll
09:13:56.683: win-capture.dll
09:13:56.683: vlc-video.dll
09:13:56.683: text-freetype2.dll
09:13:56.683: rtmp-services.dll
09:13:56.683: obs-x264.dll
09:13:56.683: obs-vst.dll
09:13:56.683: obs-transitions.dll
09:13:56.683: obs-text.dll
09:13:56.683: obs-qsv11.dll
09:13:56.683: obs-outputs.dll
09:13:56.683: obs-filters.dll
09:13:56.683: obs-ffmpeg.dll
09:13:56.683: obs-browser.dll
09:13:56.683: image-source.dll
09:13:56.683: frontend-tools.dll
09:13:56.683: enc-amf.dll
09:13:56.683: coreaudio-encoder.dll
09:13:56.683: ==== Startup complete ===============================================
09:13:56.973: All scene data cleared
09:13:56.973: ------------------------------------------------
09:13:57.079: WASAPI: Device 'Speakers (5- USB PnP Sound Device)' initialized
09:13:57.092: WASAPI: Device 'Microphone (5- USB PnP Sound Device)' initialized
09:14:04.923: warning: deprecated pixel format used, make sure you did set range correctly
09:14:05.001: warning: deprecated pixel format used, make sure you did set range correctly
09:14:05.235: [Media Source '(null)']: settings:
09:14:05.235: input: C:/Users/jeffr/Google Drive/Esports/New Stince Logo/stince-transition-final.mov
09:14:05.235: input_format: (null)
09:14:05.235: is_looping: no
09:14:05.235: is_hw_decoding: yes
09:14:05.235: is_clear_on_media_end: yes
09:14:05.235: restart_on_activate: yes
09:14:05.235: close_when_inactive: no
09:14:05.312: Switched to scene 'START STREAM'
09:14:05.355: ------------------------------------------------
09:14:05.355: Loaded scenes:
09:14:05.355: - scene 'START STREAM':
09:14:05.355: - source: 'ELGATO' (dshow_input)
09:14:05.355: - source: 'OBS-DEFAULT-BG' (image_source)
09:14:05.355: - source: 'START-OVERLAY' (browser_source)
09:14:05.355: - source: 'MIC With Xbox' (wasapi_input_capture)
09:14:05.355: - filter: 'Gain' (gain_filter)
09:14:05.355: - scene 'IN-GAME':
09:14:05.355: - source: 'WEBCAM' (dshow_input)
09:14:05.355: - filter: 'Video Delay (Async)' (async_delay_filter)
09:14:05.355: - source: 'Break-BATHROOM' (image_source)
09:14:05.355: - source: 'Break-FOOD' (image_source)
09:14:05.355: - source: 'IG - OVERLAY' (browser_source)
09:14:05.355: - scene 'BREAK':
09:14:05.355: - source: 'Break - OVERLAY' (browser_source)
09:14:05.355: - scene 'END':
09:14:05.355: - source: 'ENDING STREAM OVRLY' (browser_source)
09:14:05.355: - scene 'ASHEK':
09:14:05.355: - source: 'ASHEKOVRLY' (browser_source)
09:14:05.355: - source: 'Overlay - ASHEK' (browser_source)
09:14:11.870: ---------------------------------
09:14:11.870: [DShow Device: 'WEBCAM'] settings updated:
09:14:11.870: video device: Logitech HD Webcam C615
09:14:11.870: video path: \\?\usb#vid_046d&pid_082c&mi_02#7&367cd5c4&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
09:14:11.870: resolution: 1280x720
09:14:11.870: fps: 30.00 (interval: 333333)
09:14:11.870: format: I420
09:14:18.008: ---------------------------------
09:14:18.008: [DShow Device: 'ELGATO'] settings updated:
09:14:18.008: video device: Elgato Game Capture HD
09:14:18.008: video path: __elgato
09:14:18.008: resolution: 1920x1080
09:14:18.008: fps: 60.00 (interval: 166666)
09:14:18.008: format: UYVY
09:14:18.008: using video device audio: yes
09:14:18.008: sample rate: 48000
09:14:18.008: channels: 2
09:14:18.008: audio type: Capture
09:14:27.229: adding 255 milliseconds of audio buffering, total audio buffering is now 255 milliseconds
09:14:27.480: adding 185 milliseconds of audio buffering, total audio buffering is now 441 milliseconds
09:14:28.207: Source 'MIC With Xbox' renamed to 'MICROPHONE'
09:14:39.451: Source 'ELGATO' renamed to 'ELGATO HD CC'
09:14:48.960: User switched to scene 'IN-GAME'
09:14:50.376: A sprite cannot be drawn without a width/height
09:14:50.383: A sprite cannot be drawn without a width/height
09:14:50.401: A sprite cannot be drawn without a width/height
09:14:50.432: A sprite cannot be drawn without a width/height
09:14:50.440: A sprite cannot be drawn without a width/height
09:14:50.467: A sprite cannot be drawn without a width/height
09:14:50.488: A sprite cannot be drawn without a width/height
09:14:50.504: A sprite cannot be drawn without a width/height
09:14:50.541: A sprite cannot be drawn without a width/height
09:14:50.551: A sprite cannot be drawn without a width/height
09:14:50.570: A sprite cannot be drawn without a width/height
09:14:50.600: A sprite cannot be drawn without a width/height
09:14:50.616: A sprite cannot be drawn without a width/height
09:14:50.629: A sprite cannot be drawn without a width/height
09:14:50.647: A sprite cannot be drawn without a width/height
09:14:50.662: A sprite cannot be drawn without a width/height
09:14:50.684: A sprite cannot be drawn without a width/height
09:14:50.696: A sprite cannot be drawn without a width/height
09:14:50.715: A sprite cannot be drawn without a width/height
09:14:50.730: A sprite cannot be drawn without a width/height
09:14:50.750: A sprite cannot be drawn without a width/height
09:14:50.765: A sprite cannot be drawn without a width/height
09:14:50.782: A sprite cannot be drawn without a width/height
09:14:50.795: A sprite cannot be drawn without a width/height
09:14:50.812: A sprite cannot be drawn without a width/height
09:14:50.829: A sprite cannot be drawn without a width/height
09:14:50.850: A sprite cannot be drawn without a width/height
09:14:50.863: A sprite cannot be drawn without a width/height
09:14:50.882: A sprite cannot be drawn without a width/height
09:14:50.895: A sprite cannot be drawn without a width/height
09:14:50.913: A sprite cannot be drawn without a width/height
09:14:56.702: Last log entry repeated for 62 more lines
09:14:56.702: User switched to scene 'BREAK'
09:15:10.308: Switched to Preview/Program mode
09:15:10.308: ------------------------------------------------
09:15:22.407: Switched to scene 'BREAK'
09:15:22.418: Switched to regular Preview mode
09:15:22.418: ------------------------------------------------
09:15:53.268: ---------------------------------
09:15:53.278: [NVENC encoder: 'simple_h264_stream'] settings:
09:15:53.278: rate_control: CBR
09:15:53.278: bitrate: 6000
09:15:53.278: cqp: 0
09:15:53.278: keyint: 120
09:15:53.278: preset: default
09:15:53.278: profile: main
09:15:53.278: level: auto
09:15:53.278: width: 1600
09:15:53.278: height: 900
09:15:53.278: 2-pass: true
09:15:53.278: b-frames: 2
09:15:53.278: GPU: 0
09:15:53.278:
09:15:53.977: [Media Foundation AAC: 'simple_aac']: encoder created
09:15:53.977: bitrate: 160
09:15:53.977: channels: 2
09:15:53.977: sample rate: 44100
09:15:53.977: bits-per-sample: 16
09:15:53.977:
09:15:54.068: ==== Recording Start ===============================================
09:15:54.068: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/jeffr/Videos/2018-03-10 09-15-53.mov'...
09:16:52.418: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/jeffr/Videos/2018-03-10 09-15-53.mov' stopped
09:16:52.418: Output 'simple_file_output': stopping
09:16:52.418: Output 'simple_file_output': Total frames output: 3469
09:16:52.418: Output 'simple_file_output': Total drawn frames: 3501
09:16:52.419: ==== Recording Stop ================================================
09:17:03.187: ---------------------------------
09:17:03.187: [NVENC encoder: 'simple_h264_stream'] settings:
09:17:03.187: rate_control: CBR
09:17:03.187: bitrate: 6000
09:17:03.187: cqp: 0
09:17:03.187: keyint: 120
09:17:03.187: preset: default
09:17:03.187: profile: main
09:17:03.187: level: auto
09:17:03.187: width: 1600
09:17:03.187: height: 900
09:17:03.187: 2-pass: true
09:17:03.187: b-frames: 2
09:17:03.187: GPU: 0
09:17:03.187:
09:17:03.356: [Media Foundation AAC: 'simple_aac']: encoder created
09:17:03.356: bitrate: 160
09:17:03.356: channels: 2
09:17:03.356: sample rate: 44100
09:17:03.356: bits-per-sample: 16
09:17:03.356:
09:17:03.416: ==== Recording Start ===============================================
09:17:03.416: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/jeffr/Videos/2018-03-10 09-17-03.mov'...
09:18:58.007: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/jeffr/Videos/2018-03-10 09-17-03.mov' stopped
09:18:58.007: Output 'simple_file_output': stopping
09:18:58.007: Output 'simple_file_output': Total frames output: 6848
09:18:58.007: Output 'simple_file_output': Total drawn frames: 6862 (6875 attempted)
09:18:58.007: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 13 (0.2%)
09:18:58.008: ==== Recording Stop ================================================
09:23:08.125: User removed filter 'Gain' (gain_filter) from source 'MICROPHONE'
09:23:10.827: User switched to scene 'IN-GAME'
09:23:11.453: User switched to scene 'START STREAM'
check your input microphone boost it should be +0db
Here a picture where you can find it
reduce input volume too (75%max)
where did you plugged in your mic?
Backpanel Audio Pink/Blue
or Frontpanel Audio Pink
or USB?
It’s currently at 100% volume. I can reduce both my capture and mic to see if this helps.
I’m also going to try to put it to the default input. I’m currently using my laptop to stream and a USB sound card. I will use the default onboard jack to see if this also helps. I read on the tonor reviews that the USB apparently causes some feedback.
Also, both my camera and mic delay are set at 1600ms - yet they are not synced. Any reason why they are off yet set to the same variable?
