John Gonzalez
Hi i want to start streaming but i cant seem to find the right solution to why i cant stream efficiently. My setup is an i5 6600k, gigabyte z170 motherboard, and 8gb of ram, i should be able to stream at 720 60fps, but i can't, when i begin to play Playerunknown's Battlegrounds it lags tremendously and objects don't render in. That doesn't happen when i play without streaming as well as when i stream at 30fps, but i don't want 30. My internet speeds can't be the problem either because they look pretty good "http://beta.speedtest.net/result/6510849816.png". I need help i don't know where the problem is occurring. I have already tried setting different priorities as well as the auto configuration wizard that recommends to stream at 6000 bit-rate but using nvenc which i know inst good. Please help.
