Question / Help Avermedia LiveGamer Extreme no sound - need to restart obs
Yasaka
hey, i have a avermedia live gamer extreme with the latest stable driver (beta dont work proberly) and i choosed to only record sound from capture card. so the audiobar shows that sound of the capture card should work but when i start obs the first time you wont hear the sound in stream or in a recording.(when i change audio output mode to desktop directsound or waveout, you hear the audio without problems) the problem can easily be solved when i restart obs. but this is a little bit annoying so i hope somebody can help me with this problem. here is a log from when the capcard has no sound in recording but the bar shows it. https://gist.github.com/bfc36b85730adb9851fe922c3aca75c1
and here is a log when i restarted obs and sound works fine:
https://gist.github.com/5de1bce979c4470e1993feaf5dd976c2
