Question / Help Avermedia LGP Stream Engine not functioning in OBS Studio
ZroChi
Hello Forumdwellers!
I'm sorry for posting this here but I'm at the end of my wits, and the Avermedia support hasn't answered.
Facts:
Windows 10 Pro 1607, build 14393.447 OBS Studio version 0.16.5 Avermedia driver v3.7.x.39 Stream Engine V1.0.0.35
When using the stream engine I am able to select it in the Video Capture Device menu, but the preview just stays gray. Using ReCentral works and shows the console feed (Playstation 3). Trying to go into the settings of the Video Capture Device after it has been set as a source also crashes OBS. Does anyone have an idea as how to get the Stream Engine working?
Here's some pictures of settings etc.
Properties for 'Video Capture Device' http://i.imgur.com/TXPnPUC.png
Stream Engine Settings (When OBS does NOT have the Stream Engine Selected) http://i.imgur.com/OkFIa0X.png
Stream Engine Settings (When OBS DOES have the Stream Engine Selected) http://i.imgur.com/36ObcrW.png
  • 2016-11-13 00-49-36.txt
ZroChi
For the things I've already tried:
  • Closing Google Chrome and Skype only solves the issue of the Stream Engine not showing up as a Video Capture Device (This I already knew from previous problems with the device)
  • Restarting all devices
  • Making sure the output settings on the device are the same as the input settings for my OBS
  • Using the Beta Stream Engine (This caused more trouble then it solved by breaking ReCentral)
