Question / Help Audio stuttering when using a capture card (AVerMedia LGP LITE GL310)
Axorm
I have the exact same issue, same stuttering with audio and looking for a solution :/
(and I can't use the Avermedia Stream Engine since it's not 64bit compatible and my 32bit version of OBS crashes all the time...)
Sapiens
Forum Moderator
Using Stream Engine and adding it as the video capture device is the solution to this problem.
@Axorm If OBS is crashing then ask for help with that, in your own thread, with crash logs provided.
Unison
Hi! It is not possible to select Stream Engine.
