Hi!, this is my first post at OBS forums. I'm Nico from Buenos Aires. I'm 40 and recently started using OBS for streaming impromptu dj sets.
The problem is that when setting a new Audio Input Capture source i can see on the Audio Mixer window a single color line and not two indicating source is mono?
So, master output going thru speakers sounds in stereo like it should but when i listen to the recording of the stream i can hear the music but tracks are coming out in mono
i'm using a Lenovo idea Pad 3 with Win10 Home hooked to a MAYA 44 USB audio interface (ASIO / 4 RCA out - 4 RCA in) I'm also using a Behringer NOX 404 2-channel mixer connected to the maya 44 OUT RCAs
finally using a usb type B to C cable (cheap printer one) to connect the mixer to the pc usb type c port which will be the main OBS audio source
tried checking the mono box on all devices but no dice. still single green/yellow/red line.
OBS Logfile:
https://obsproject.com/logs/R53zO_95yDCgXDE
Any help will be greatly appreciated.
OBS Logfile:
