Question / Help Audio Problems
treeves
I need help with some audio problems. I've attached a zip file with an mp4 inside of it, which will example the problem I'm having. Basically, the audio will either not come through or it will stutter and make fuzz. I've also uploaded the last log:
https://gist.github.com/844391baa5c77d973999
Please, I would love some help. I have no idea what I'm doing and really can't put off fixing this any longer. If no one knows how to fix this, I would appreciate potentially pointing me in the direction of someone who could?
For reference, I'm running a Roxio GameCap HDPro on the newest version of OBS MP. I'm not sure if it's an issue with OBS or Roxio. The problem also only seems to occur while running the game shown in the example?
Please and thanks, T.
EDIT: Uploaded it as unlisted.
I've only tested it with Bayonetta and Splatoon, and it didn't happen at all with Splatoon. Maybe it's just a coincidence and was behaving proper? It might just be my computer, but the Roxio software already has major issues. It squishes the capture screen and I get a wonky video as a result, and frequently it will freeze up on me and not allow me to close it without waiting anywhere up to 30 minutes. I'm fairly positive the stutter doesn't happen Roxio's software, but I can double check if you like!
Bump??? I'm at a point where I can't record until it's fixed and I don't think I should let it go on any longer!
Do we know if this is something on their part or not, though? If I personally can't do anything but wait, I'm fine with that. If this is on my end, I really need some help. :( I'm having recording withdrawals, lol.
