Question / Help Audio Problems
Zklopper
hey, I just started Using OBS on my Mac using Wavetap. At first when I started streaming using my multi-aggragate device It worked fine with a little bit of an echo, Later this week I opened OBs and used the Multi-aggragate device and it had a crazy echo that was like 3 seconds long. I don't have my stream open and it is in my headphone even if I'm not streaming.
Let me know Thanks
-Zach
Lain
Forum Admin
Lain
Forum Moderator
Developer
I don't understand the problem, could you be more specific? Multi-aggregate device?
If you're having echo it usually means that you're capturing the same thing more than once or you're watching your own stream while streaming. Or wavtap/soundflower is configured incorrectly or something.
