Hey everybody!
So my buddy and I have been streaming for awhile now and since we really haven't got a following until now we noticed some things with the audio.Im not super techy so this may sound stupid.
It seems to me that desktop/in game audio is pretty loud in my ears but when its on the stream its really quiet. I therefore turn it up in my ears (uncomfortably loud) so the audience can hear background noise better. I accidentally talk really loud since I can't hear myself as well because of this. I don't know if this is because the audio is getting condensed and therefore quieter through sound flower and then through OBS?
Also once in awhile in OBS the green bar that says audio is getting pickup will get stuck into a gray bar for my desktop audio. I then never know if its really working!
Also once in awhile an echo is picked up during the stream specifically when using Skype.
I usually use Soundflower with Quicktime Player to record and it works well because I just later on edit the background audio when Im not speaking. So it could be my sound flower settings?
I use some basic 15 dollar SkullCandy headphones with a mic on the cord. I have used the Beats looking big SkullCandy headphones before but with no mic. Similar results. I have to turn it up loud to get it to record at a normal volume.
OBS Specs:
Sample Rate 44.1khz
Desktop Audio Device: Soundflower 2 channel
Mic/auxiliary: Built in Microphone
audio bitrate: 128
SoundFlower settings(when I have it on, and my headphones in):
Aggregate Device: 4 in/ 4 out
Sample Rate:44100.0 Hz
Clock source: Built in Microphone (SHOULD THIS BE CHANGED?)
Using:
2 Built in Microphone No Drift
Built in output Drift
Soundflower 2 channel Drift
Input channels: 3 and 4 are Soundflower 2 ch
Output channel: 1 and 2 are Built in output, 3 and 4 are Built in microphone
Not using:
Soundflower 64 channel
Do I need to change some settings? Do I need a better headset or mic and headset duo? If so, any suggestions would be awesome! Thanks!
OBS Specs:
Sample Rate 44.1khz
audio bitrate: 128
Using:
Not using:
