AUDIO PROBLEMS
GameXplorer
Hello, I have been using OBS for some time to record my videos but I have had a problem and I put the external microphone in the settings and if I speak I hear it well but if I shut up the audio is disconnected it is very strange and it also happens that if I say also for example I only hear it too and it is very frustrating and I have tried everything other headphones restart the program restart the computer uninstall and reinstall the program and nothing the only thing that fixes the problem but then the only thing that makes the audio come back is to go to options change to the internal one and put it back to the external one. i uninstall i reinstall the program i nothing the only thing that makes the audio back is to go to options change to the internal i put it back to the external that is the only thing that fixes the problem but then after a while it reconnects please help me i if it was little if I use the internal microphone does not occur this problem please help me if I can not record well thank you
