Bug Report Audio Problems
cnunes73ucb
Please Help me to fix these error
19:49:58.408: [CoreAudio encoder]: Adding CoreAudio AAC encoder
19:49:58.412: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
19:49:58.765: [AMF] Unable to load 'amfrt64.dll', error code 126.
19:49:58.769: [AMF] AMF Test failed due to one or more errors.
19:49:58.769: Failed to initialize module 'enc-amf.dll'
19:49:58.886: [obs-browser]: Version 2.8.6
19:49:58.996: Couldn't find VLC installation, VLC video source disabled
19:49:59.021: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
19:49:59.021: No blackmagic support
19:50:00.934: ---------------------------------
19:50:00.934: [DShow Device: 'FILMADORA'] settings updated:
19:50:00.934: video device: LGPLite Stream Engine
19:50:00.934: video path:
19:50:00.934: resolution: 1280x720
19:50:00.934: flip: 0
19:50:00.934: fps: 30.00 (interval: 333333)
19:50:00.934: format: YUY2
19:50:00.934: using video device audio: yes
19:50:00.934: sample rate: 44100
19:50:00.934: channels: 2
19:50:00.934: audio type: Capture
19:50:04.084: warning: deprecated pixel format used, make sure you did set range correctly
19:50:04.085: warning: Warning: data is not aligned! This can lead to a speed loss
19:50:04.118: warning: deprecated pixel format used, make sure you did set range correctly
19:50:04.156: warning: deprecated pixel format used, make sure you did set range correctly
19:50:04.196: warning: deprecated pixel format used, make sure you did set range correctly
carlmmii
What is your actual issue? Posting a snippet of a log file does not tell us anything - nothing in those logs stands out as an issue on their own.
cnunes73ucb
Hi,
I am using a Behringher Q502usb to sound and Avermedia GL310 to capture a Image from Camera to do Live Stream in Youtube.
In my video below after some time (39:30) the voice sounds starts robotic!!
https://www.youtube.com/watch?v=VXlr_s-2Tew
it's an intermittent problem because sometimes I have a problem and sometimes I don't
Does anybody has some suggestion?
  • 2020-05-07 15-53-50.txt
cnunes73ucb
After use this attached configuration I never saw the problem again.
  • Configuração Catedral_19052020.pdf
