Question / Help audio problem
radicalx88
I am trying to record Star wars knights of the old republic most of it is working great but the problem is voice the characters lips move then will hear there voice several seconds after around 8 to 10 seconds I tried to figure it out but can't seem to fix it.
http://pastebin.com/WxkjyFNQ
  • 2016-12-05 13-49-27.txt
Joe33345
14:01:09.742: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 577 (54.0%)
Sorry man but your processor is the issue here. It just can't handle the work load of recording and playing on the same machine.
I would try kicking the 'downscale resolution' on to 1280x720 at record at 30fps. See if that helps. :-)
radicalx88
I will try that but I have played and recorded games with higher demand with no problems it is only this game that does it
Getset2go
I NEED SUPPORT please...
I try to live stream using OBS however doing so i hear my own stream overlaying and causing an echo while i stream through my headphones..
Reading other posts with similar issues I can tell you I don't watch my own stream while I am streaming, I only pop out the chat to keep an eye on.
I want my desktop audio to be streamed, that is game audio and skype, these both come through OBS on my open volume mixer.
If I turn that down to stop the echo, they can't hear my game volume or skype through the stream but they can hear me.
I believe some people have the same issue but others on here think its an easy solution like muting your stream but its not that at all. I can record no problem it is only streaming i get an echo this is for PC. Normally I use my capture card for console gaming, which never gives me issues.
