Audio Mixer volume sliders too small.
almarc11
I use OBS on a laptop and a desktop both running the same versions of OBS and Windows 10. When using the audio mixer on my laptop the volume sliders are nice and large and easy to grab with the mouse. On my desktop, the sliders are the same width as the slider line and are hard to grab since they are only a couple pixels wide. I think this is a Windows issue, but I have no idea how to adjust this. I have no idea why the two machines display the sliders differently. Any help?
Most difference between displays is DPI value of the display device and Windows "Scaling" option (100%, 150%, 200%, 250% etc). Some UI in OBS is hardcoded to occupy certain amount of pixels. All default themes uses not well scalable pixel metric. There is difference.
I tried changing the scaling option in Windows and even moving the OBS windows to a monitor with the same resolution, but nothing changed. I'm also using the same theme. I still think this is something in Windows associated with slider controls.
