W00tkaeppi
Hi everyone,
i really have some troubles with my video capture. In my video you can hear that after a few seconds the sound recording of the game suddenly gets worse.
https://youtu.be/s9DrzafKBnc
Please can anyone give me a good help to solve this problem?
Greetings and really great thanks to everyone who will and can help me.
W00t
Log-File (Notice: This is the Log-File from my third PC with the same issues while recording/capturing via OBS/NDI):
W00t
12:37:12.088: CPU Name: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
12:37:12.088: CPU Speed: 3067MHz
12:37:12.088: Physical Cores: 2, Logical Cores: 4
12:37:12.088: Physical Memory: 8119MB Total, 5779MB Free
12:37:12.088: Windows Version: 10.0 Build 17134 (revision: 706; 64-bit)
12:37:12.089: Running as administrator: false
12:37:12.089: Aero is Enabled (Aero is always on for windows 8 and above)
12:37:12.089: Windows 10 Gaming Features:
12:37:12.089: Game DVR: On
12:37:12.095: Sec. Software Status:
12:37:12.097: Windows Defender Antivirus: enabled (AV)
12:37:12.097: Windows-Firewall: enabled (FW)
12:37:12.098: Windows Defender Antivirus: enabled (ASW)
12:37:12.098: Current Date/Time: 2019-05-09, 12:37:12
12:37:12.098: Browser Hardware Acceleration: true
12:37:12.098: Portable mode: false
12:37:14.111: OBS 23.1.0 (64-bit, windows)
12:37:14.111: ---------------------------------
12:37:14.140: ---------------------------------
12:37:14.140: audio settings reset:
12:37:14.140: samples per sec: 48000
12:37:14.140: speakers: 2
12:37:14.161: ---------------------------------
12:37:14.161: Initializing D3D11...
12:37:14.161: Available Video Adapters:
12:37:14.164: Adapter 1: NVIDIA GeForce GT 640
12:37:14.164: Dedicated VRAM: 1032323072
12:37:14.164: Shared VRAM: 4256946176
12:37:14.164: output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:37:14.167: Loading up D3D11 on adapter NVIDIA GeForce GT 640 (0)
12:37:14.237: D3D11 loaded successfully, feature level used: 45056
12:37:15.351: ---------------------------------
12:37:15.351: video settings reset:
12:37:15.351: base resolution: 1920x1080
12:37:15.351: output resolution: 1920x1080
12:37:15.351: downscale filter: Bilinear
12:37:15.351: fps: 60/1
12:37:15.351: format: NV12
12:37:15.351: YUV mode: 709/Partial
12:37:15.352: NV12 texture support enabled
12:37:15.355: Audio monitoring device:
12:37:15.355: name: Standard
12:37:15.355: id: default
12:37:15.356: ---------------------------------
12:37:15.500: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:37:15.524: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
12:37:15.626: [AMF] AMF Test failed due to one or more errors.
12:37:15.626: Failed to initialize module 'enc-amf.dll'
12:37:15.922: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
12:37:16.044: [obs-browser]: Version 2.3.1
12:37:16.144: NVENC supported
12:37:16.198: Failed to load 'de-DE' text for module: 'obs-ios-camera-source.dll'
12:37:16.198: Loading iOS Camera Plugin (version 2.5.0)
12:37:16.221: Failed to load 'de-DE' text for module: 'obs-ndi.dll'
12:37:16.221: [obs-ndi] hello ! (version 4.5.2)
12:37:16.221: [obs-ndi] Trying 'C:\Program Files\NewTek\NewTek NDI 3.5 Redist\v3'
12:37:16.222: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NewTek NDI 3.5 Redist/v3/Processing.NDI.Lib.x64.dll'
12:37:16.272: [obs-ndi] NDI runtime loaded successfully
12:37:16.284: [obs-ndi] NDI library initialized successfully
12:37:16.611: Couldn't find VLC installation, VLC video source disabled
12:37:16.668: No blackmagic support
12:37:16.766: ---------------------------------
12:37:16.766: Loaded Modules:
12:37:16.766: win-wasapi.dll
12:37:16.766: win-mf.dll
12:37:16.766: win-dshow.dll
12:37:16.766: win-decklink.dll
12:37:16.766: win-capture.dll
12:37:16.766: vlc-video.dll
12:37:16.766: text-freetype2.dll
12:37:16.766: rtmp-services.dll
12:37:16.766: obs-x264.dll
12:37:16.766: obs-vst.dll
12:37:16.767: obs-transitions.dll
12:37:16.767: obs-text.dll
12:37:16.767: obs-qsv11.dll
12:37:16.767: obs-outputs.dll
12:37:16.767: obs-ndi.dll
12:37:16.767: obs-ios-camera-source.dll
12:37:16.767: obs-filters.dll
12:37:16.767: obs-ffmpeg.dll
12:37:16.767: obs-browser.dll
12:37:16.767: image-source.dll
12:37:16.767: frontend-tools.dll
12:37:16.767: enc-amf.dll
12:37:16.767: decklink-ouput-ui.dll
12:37:16.767: coreaudio-encoder.dll
12:37:16.767: ---------------------------------
12:37:16.768: ==== Startup complete ===============================================
12:37:16.805: All scene data cleared
12:37:16.805: ------------------------------------------------
12:37:16.853: WASAPI: Device 'Kopfhörer (2- High Definition Audio-Gerät)' initialized
12:37:16.884: WASAPI: Device 'Mikrofon (VB-Audio VoiceMeeter VAIO)' initialized
12:37:16.889: [obs-ios-camera-plugin] Creating instance of plugin!
12:37:16.890: [obs-ios-camera-plugin] Loaded Settings: Connecting to device
12:37:16.890: [obs-ios-camera-plugin] Connecting to device
12:37:16.929: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Mic/Aux)
12:37:16.929:
12:37:16.940: [obs-ndi] started A/V threads for source 'W00TGAMING (W00TGAMING)'
12:37:16.941: [obs-ndi] video thread for 'NDI W00TGAMING' started
12:37:16.941: [obs-ndi] audio thread for 'NDI W00TGAMING' started
12:37:17.108: WASAPI: Device 'Mikrofon (VB-Audio VoiceMeeter VAIO)' initialized
12:37:17.110: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{8e668c3f-2433-48c2-8ea4-e589614f920e}' not found. Waiting for device
12:37:17.232: Switched to scene 'MAIN'
12:37:17.232: ------------------------------------------------
12:37:17.232: Loaded scenes:
12:37:17.232: - scene 'MAIN':
12:37:17.232: - source: 'NDI W00TGAMING' (ndi_source)
12:37:17.232: - filter: 'Rauschunterdrückung' (noise_suppress_filter)
12:37:17.233: - filter: 'Kompressor' (compressor_filter)
12:37:17.233: - filter: 'Schärfen' (sharpness_filter)
12:37:17.233: - source: 'W00TLOGO' (image_source)
12:37:17.233: - source: 'AUNA MCKROFON' (wasapi_input_capture)
12:37:17.233: - filter: 'Rauschunterdrückung' (noise_suppress_filter)
12:37:17.233: - source: 'TERRATEC LINE IN' (wasapi_input_capture)
12:37:17.233: - source: 'WEBCAM IPHONE 5' (ios-camera-source)
12:37:17.233: - filter: 'Chroma Key' (chroma_key_filter)
12:37:17.233: - filter: 'Farbkorrektur' (color_filter)
12:37:17.233: - source: 'GEOGUESSR' (color_source)
12:37:17.233: - source: 'Farbquelle' (color_source)
12:37:17.233: - source: 'Bild' (image_source)
12:37:17.233: ------------------------------------------------
12:37:17.411: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
12:37:17.411:
